Maxxisun.app API to MQTT bridge (MaxxiCharge battery storage)
Maxxisun is a german vendor of the MaxxiCharge systems - balcony power plant systems with zero feed-in.
This flow calls the API behind the maxxisun.app and forward the results to a MQTT broker. With this you can master your smarthome project like creating dashboards or storing data in a influx database.
You have to change:
  • replace your personal Bearer token
  • upload the server certificate
  • modify your mqtt server and topic
See the comment node for further information.
Additional tips: You can use this flow without a MQTT server and forward the response direct to a graphical dashboard.
If your system uses a PowerOpti smartmeter sensor you can use the official PowerFox API too for enhancing additional data.
Have fun!
[{"id":"429e56466fc0ca6e","type":"inject","z":"87fe543b93444457","name":"10 sec trigger","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"10","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":180,"y":180,"wires":[["a31d36f0bb016f48"]]},{"id":"a31d36f0bb016f48","type":"http request","z":"87fe543b93444457","name":"Call Maxxisun.app API ","method":"GET","ret":"txt","paytoqs":"ignore","url":"https://maxxisun.app:3000/api/last","tls":"798787818db54cea","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[{"keyType":"other","keyValue":"Authorization","valueType":"other","valueValue":"Bearer <insert_your_token>"},{"keyType":"other","keyValue":"Origin","valueType":"other","valueValue":"https://maxxisun.app"},{"keyType":"other","keyValue":"Referer","valueType":"other","valueValue":"https://maxxisun.app/"},{"keyType":"other","keyValue":"User-Agent","valueType":"other","valueValue":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:128.0) Gecko/20100101 Firefox/128.0"},{"keyType":"other","keyValue":"Accept","valueType":"other","valueValue":"application/json, text/plain, */*"},{"keyType":"other","keyValue":"Accept-Language","valueType":"other","valueValue":"de,en-US;q=0.7,en;q=0.3"},{"keyType":"other","keyValue":"Accept-Encoding","valueType":"other","valueValue":"gzip, deflate, br, zstd"}],"x":460,"y":180,"wires":[["4827eaeed7e8f5b1","4f66fd67ea72ae99"]]},{"id":"4827eaeed7e8f5b1","type":"debug","z":"87fe543b93444457","name":"Maxxisun Request","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":770,"y":240,"wires":[]},{"id":"4f66fd67ea72ae99","type":"mqtt out","z":"87fe543b93444457","name":"MQTT: iot/maxxisun/state","topic":"iot/maxxisun/state","qos":"","retain":"true","respTopic":"","contentType":"","userProps":"","correl":"","expiry":"","broker":"cf66559d24028e47","x":790,"y":180,"wires":[]},{"id":"a0c0fe692e1ebc9a","type":"comment","z":"87fe543b93444457","name":"required preparations","info":"# Get authorization\n - Login to https://maxxisun.app\n - Open the developer tools (F12)\n - Enter the tab \"network analysis\"\n - Search for GET request to maxxisun.app:300\n - Select one of these lines\n - Visit the header lines\n - Search for \"Authorization Bearer\"\n - Copy the \"Bearer xxxx\" Text\n - Insert or replace this string in the node \"Call maxxisun.app API\" as header line \"Authorization\"\n\n# Install certificate\n - download the certificate from https://maxxisun.app as *.crt\n - upload the certificate in node \"Call maxxisun.app API\" as CA server certificate\n - Test the api call with the \"inject\" node\n\n# Test\n- use the \"inject\" node to test the API\n- activate the \"debug\" node and visit debug messages\n\n","x":460,"y":120,"wires":[]},{"id":"4b09799107027315","type":"comment","z":"87fe543b93444457","name":"Change MQTT server and topic","info":"","x":810,"y":120,"wires":[]},{"id":"798787818db54cea","type":"tls-config","name":"","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"maxxisun.app.crt","servername":"","verifyservercert":false,"alpnprotocol":""},{"id":"cf66559d24028e47","type":"mqtt-broker","name":"MQTT Broker","broker":"192.168.1.1","port":"1883","clientid":"","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"iot/nodered/State","birthQos":"0","birthRetain":"false","birthPayload":"ONLINE","birthMsg":{},"closeTopic":"iot/nodered/State","closeQos":"0","closeRetain":"false","closePayload":"SHUTDOWN","closeMsg":{},"willTopic":"iot/nodered/State","willQos":"0","willRetain":"false","willPayload":"OFFLINE","willMsg":{},"userProps":"","sessionExpiry":""}]
Created 1 year, 4 months ago
Rating: 5 2
  • comment (x2)
  • http request (x1)
  • mqtt out (x1)
  • mqtt-broker (x1)
  • tls-config (x1)
  • photovoltaic
  • influxdb
  • maxxisun
  • maxxicharge
  • mqtt
  • dashboard
