ttb-node-owntracks 0.0.4
A Node-RED node to use Owntracks GPS position
A Node-RED node to use Owntracks GPS position.
Run the following command in the root directory of your Node-RED install, usually this is ~/.node-red .
npm install ttb-node-owntracks
Provides one node to receive an Owntracks GPS signal.
Example
You can check out an example of a flow in the ./lib directory of this repo.
