thethingbox-node-sensortag 0.0.19
Sensortag node for thethingbox, compatible with node-red
npm install thethingbox-node-sensortag
A node for TheThingBoxTheThingBox or Node-RED to add a sensorTag node.
You have to install the bluetooth library in your system :
apt-get install bluetooth bluez-utils blueman libbluetooth-dev
Run the following command in the root directory of your Node-RED install (TheThingBox : /root/thethingbox/node_modules/node-red)
With this node, you will be able to get all data from the sensortag by bluetooth. You will find all the data in the msg.payload. Other informations about connection are available in msg.uuid and msg.state
Version: 0.0.19
Updated 2 years, 7 months ago
0 in the last day
71 in the last week
118 in the last month
  • sensorTag
  • thethingbox node
  • thethingbox
  • sensortag
  • thethingbox-team
