snappy-ros 0.3.4
A collection of Node-red nodes for connecting with ROS (Robot Operating System)
npm install snappy-ros
A collection of Node-RED nodes for connecting with ROS (Robot Operating System)
Badges
Build Status Coverage Status dependencies Status Known Vulnerabilities
npm GitHub tag license npm
NPM
Prerequisites
To install the stable version run the following command in your Node-RED user directory (typically ~/.node-red):
npm i snappy-ros
Open your Node-RED instance and you should have ROS nodes available in the palette.
If you want to try the latest version from github, you can install it by
npm i SnappyRobotics/snappy-ros
To change the ROS node name (as to be seen in rqt_graph) add this line in the json settings file (typically ~/.node-red/settings.json):
rosNodeName: 'Node-RED',
and replace the above Node-RED with your required name.
Nodes :
Subscriber
Subscriber how to
Publisher
Publisher how to
TODO:
  • Add service client and server nodes
  • Parameter nodes(setter and getter)
  • Write Unit Tests
and many more comming in next couple of days.
Version: 0.3.4
Updated 7 years, 1 month ago
License: GPL-3.0
Rating: 1.0 1
1 in the last week
  • ros-subscriber
  • ros-publisher
  • ros
  • rosnodejs
  • snappy
