nr-regexp-filter 1.0.1
Filter messages using a regexp on the given message property.
npm install nr-regexp-filter
A node that filters messages using the given property name and regular expression. The property name is deep-searched, so you can use something like "payload.my.prop" to test over "prop".
When the regexp matches the whole message will be returned, otherwise the whole message will be dropped.
Example: .(json|xml)$ matches everything that ends with .json and .xml
install
Go to /.node-red and launch
It will creates a node_modules folder with the needed package. Restart the server to load the new palette.
Version: 1.0.1
Updated 7 years, 5 months ago
1 in the last week
  • filter
  • filter
  • regexp
  • regular expression
