node-shri-dashboard 2.3.11-beta
A set of dashboard nodes for Node-RED
npm install node-shri-dashboard
Developers
npm install
The plugin uses the dist folder if it exists and contains an index.html file. Make sure to delete it if you want to use the non-minified version. After changing the front-end code in the src folder, use gulp to update the minified files and update the appcache manifest.
gulp
We also have suggested lint and js styles that can be checked with:
gulp lint
gulp jscs
If submitting a Pull Request (PR) please do NOT include the minified /dist files.
Thank you.
Version: 2.3.11-beta
Updated 3 months, 1 week ago
13 in the last day
107 in the last week
383 in the last month
  • ui_button
  • ui_dropdown
  • ui_switch
  • ui_slider
  • ui_numeric
  • ui_text_input
  • ui_date_picker
  • ui_colour_picker
  • ui_form
  • ui_text
  • ui_gauge
  • ui_chart
  • ui_audio
  • ui_toast
  • ui_ui_control
  • ui_template
  • ui_link
  • ui_tab
  • ui_group
  • shrikantzarekar
  • Shrikant
