node-red-vis 0.4.2
Visualisation for node-red. Based on ioBroker.vis
npm install node-red-vis
Logo node-red VIS
NPM version Downloads
NPM
This project adds web visualisation to Node-RED. It is based on ioBroker.vis.
Functionality
We introduce "vis in" node which creates the visualisation server with communication via socket.io.
Demo interface
Demo interface
cd $NODE_RED_HOME
Create "advanced => vis in" node and 3 inject nodes as pictured:
node-red
Here is code to import: [{"id":"a26bad1e.5d945","type":"vis in","language":"en","x":393.09092712402344,"y":81.09089660644531,"z":"4004eda7.bffb14","wires":[["1b331485.e4cceb"]]},{"id":"1d96675d.e26999","type":"inject","name":"","topic":"/kitchen/lamp","payload":"true","payloadType":"string","repeat":"","crontab":"","once":false,"x":184.0908966064453,"y":54.09089660644531,"z":"4004eda7.bffb14","wires":[["a26bad1e.5d945"]]},{"id":"e72316cd.18dce8","type":"debug","name":"","active":true,"console":"false","complete":"false","x":686.0910186767578,"y":80.09089660644531,"z":"4004eda7.bffb14","wires":[]},{"id":"d9c35749.263ca8","type":"inject","name":"","topic":"/kitchen/lamp","payload":"false","payloadType":"string","repeat":"","crontab":"","once":false,"x":185.33331298828125,"y":112.33329772949219,"z":"4004eda7.bffb14","wires":[["a26bad1e.5d945"]]},{"id":"2d3eee9.fd2c112","type":"inject","name":"","topic":"/balkon/temperature","payload":"22","payloadType":"string","repeat":"","crontab":"","once":false,"x":197.20001220703125,"y":166.1999969482422,"z":"4004eda7.bffb14","wires":[["a26bad1e.5d945"]]},{"id":"1b331485.e4cceb","type":"switch","name":"","property":"topic","rules":[{"t":"eq","v":"/kitchen/lamp"},{"t":"eq","v":""}],"checkall":"true","outputs":2,"x":523.2000274658203,"y":81.19999694824219,"z":"4004eda7.bffb14","wires":[["e72316cd.18dce8"],[]]}]
Deploy it. After deploying go to http://localhost:1880/vis/edit.html and create "basic - ctrl Bulb on/off":
basic
and "RGraph - Gauge-Basic":
RGraph-Gauge-Basic
Write into Object ID of "basic - ctrl Bulb on/off" - "/kitchen/lamp":
ctrl-Bulb(On-Off)
and into Object ID of "RGraph - Gauge-Basic" - "/balkon/temperature":
RGraph-Gauge
Wait for the project saved (about 3 seconds) and after that click here:
Close
You will see something like this:
Runtime
If you click on lamp following payload will be sent:
Debug
You can forward this message to your hardware to control it.
There is a possibility to export project into vis:
Debug
Insert following code into dialog edit field:
  "settings": {
    "style": {
      "background_class": "hq-background-blue-marine-lines"
    "theme": "redmond",
    "sizex": "",
    "sizey": "",
    "hideDescription": false,
    "gridSize": ""
  "widgets": {
    "e00001": {
      "tpl": "tplBulbOnOffCtrl",
      "data": {
        "oid": "/kitchen/lamp"
      "style": {
        "left": "8px",
        "top": "8px",
        "width": "132px",
        "height": "159px"
      "widgetSet": "basic"
    "e00002": {
      "tpl": "tplRGgauge",
      "data": {
        "min_value": "0",
        "max_value": "100",
        "factor": "1",
        "value_offset": "0",
        "labels_color": "#000000",
        "oid": "/balkon/temperature"
      "style": {
        "left": "148px",
        "top": "9px",
        "width": 200,
        "height": 200
      "widgetSet": "RGraph"
  "rerender": false,
  "filterList": [],
  "activeWidgets": []
Debug
The only issue is at start all drawn controls must receive the value.
You can inspire yourself here. This is a Live-Version of ioBroker.vis!
Change log
v 0.4.2 (2016-06-17)
  • (bluefox) fix name of google fonts
v 0.4.1 (2016-06-15)
  • (bluefox) update vis version to 0.10.5
v 0.4.0 (2016-06-14)
  • (bluefox) update all vis packages
v 0.3.2 (2015-11-10)
  • (bluefox) fix install errors and support of npm 3.x
v 0.3.0 (2015-11-02)
  • (bluefox) support of latest version of iobroker.vis
v 0.2.2 (2015-08-14)
  • (bluefox) enable to send "vis.control.command" to vis, like
     {"command": "refresh", "instance": "FFFFFFFF"}
to refresh the view. Read here more about commands.
  • (bluefox) remove jshint warnings.
Version: 0.4.2
Updated 9 years, 7 months ago
License: CC-BY-NC-4.0
51 in the last week
  • vis in
  • vis
  • ioBroker
  • visualisation
  • web front
  • bluefox
  • hobbyquaker
