node-red-node-what3words 0.1.11
A Node-RED node to convert locations to/from what3words
npm install node-red-node-what3words
A Node-RED node to convert positions to what3words...
Pre-reqs
You will need a valid API key from what3words
Uses What 3 Words to convert a location to 3 unique words. and vice versa. Don't ask... just try it...
To convert position to words it requires
  • msg.location.lat
  • msg.location.lon
or
  • msg.payload.lat
  • msg.payload.lon
or
  • msg.payload containing a string lat,lon
To convert words to position it requires
  • msg.payload containing a string of unique.three.words
A 3 word string separated by dots.
The API-key is stored in a separate credentials file.
Note: This is an online service and requires a live internet connection and a valid API key to work correctly.
See what3words for more details.
Example flow:
[{"id":"f38eba15.0c7148","type":"inject","name":"","topic":"","payload":"calibrate.newlyweds.switched","payloadType":"string","repeat":"","crontab":"","once":false,"x":646,"y":319,"z":"cf058368.30fa8","wires":[["22d6b2a5.dd294e"]]},{"id":"22d6b2a5.dd294e","type":"what3words","title":"","name":"","x":881,"y":317,"z":"cf058368.30fa8","wires":[["9caf8aa8.635078"]]},{"id":"9caf8aa8.635078","type":"debug","name":"","active":true,"console":false,"complete":"true","x":1077,"y":315,"z":"cf058368.30fa8","wires":[]}]
Version: 0.1.11
Updated 4 years, 11 months ago
2 in the last week
  • what3words
  • what3words
