node-red-node-upm 0.3.0
Node-RED nodes to talk to sensors supported by the UPM library
npm install node-red-node-upm
node-red-node-upm
Run the following command in the root directory of your Node-RED install, usually this is ~/.node-red .
Only tested on the Intel Edison so far, but it should work on other platforms supported by MRAA and UPM.
Ensure you have the latest firmware running, and have Node-RED installed.
See the Intel Downloads for hardware / downloads for your particular board.
If you do need to install Node-RED, you can do this as follows from the home directory of the root user
    npm install -g --unsafe-perm node-red
    mkdir .node-red
    cd .node-red
Then run
node-red
Supported Sensors
  • Grove Starter Kit
    • Grove Push Button
    • Grove Touch Button
    • Grove Relay
    • Grove Light Sensor
    • Grove LED
    • Grove RGB LCD
    • Grove Rotary Angle Sensor
    • Grove Sound Sensor
    • Grove Temperature Sensor
    • Grove Servo
  • Arduino 101
    • Built in Curie IMU
  • ... more to follow
Screenshot
screenshot
Version: 0.3.0
Updated 1 year ago
0 in the last day
34 in the last week
116 in the last month
  • UPM-Grove-Button
  • upm-grove-led
  • upm-grove-light
  • UPM-Grove-Relay
  • upm-grove-rgb-lcd
  • upm-grove-rotary
  • upm-grove-sound
  • upm-grove-temperature
  • upm-grove-servo
  • upm-curieimu
  • sensors
  • mraa
  • upm
  • intel
  • edison
  • galileo
  • w4ilun
