node-red-node-twilio 0.1.0
A Node-RED node to send SMS messages via the Twilio service.
npm install node-red-node-twilio
Sends an SMS message or make a voice call using the Twilio service.
The Twilio out node is configured to send SMS or make call, depending on the option selected you enter the phone number or phone number and a URL to create the TWiML response file.
msg.payload is used as the body of the message. The node can be configured with the number to send the message to. Alternatively, if the number is left blank, it can be set using msg.topic. The payload can also be the URL to create the TWiML response file.
You must have an account with Twilio to use this node. You can register for one here.
There is an example of using this node to create a simple IVR here.
Version: 0.1.0
Rating: 1.0 1
154 in the last week
  • twilio-api
  • twilio out
  • twilio
  • sms
  • Andrew Lindsay
  • Dave Conway-Jones
