node-red-node-timeswitch 0.0.6
A Node-RED node to provide a simple timeswitch to schedule daily on/off events.
npm install node-red-node-timeswitch
A Node-RED node to provide a simple timeswitch node to schedule daily on/off events.
Sets msg.payload to 1 during on times, and 0 during off times.
Also uses the suncalc module to allow use of dawn and dusk.
Dawn and dusk times can be offset both positively (+ve) for minutes after dawn or dusk, and negatively (-ve) for minutes before dawn or dusk..
The output emits a msg.payload of 1 or 0 every minute depending on whether the current time is during the selected on time or off time.
If you just need the transitions from 0->1 or 1->0 then follow this node with an RBE node.
You may also optionally specify a msg.topic if required.
Note: For a more complex version with more built-in options see Pete Scargill's node-red-contrib-bigtimer node.
Version: 0.0.6
Updated 8 months, 1 week ago
6 in the last day
136 in the last week
877 in the last month
  • timeswitch
  • timeswitch
  • timer
  • scheduler
  • dceejay
  • knolleary
