node-red-node-sensortag 0.0.19
A Node-RED node to read data from a TI SensorTag
npm install node-red-node-sensortag
This node adds support to Node-RED to read from the Texas Instruments SensorTag.
Pre-requisites
You will need a suitable Bluetooth Low Energy (BLE) stack and drivers for your hardware
  • for example Bluez 5.2.x or better.
Raspberry Pi
Install Bluetooth drivers and bluez stack, and set executable by non-root user
sudo apt-get install libbluetooth-dev libudev-dev pi-bluetooth
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
npm i node-red-node-sensortag
The SensorTag is a Bluetooth LE device hosting the following sensors:
  • Humidity and Temperature
  • Ambient & IR Temperatures
  • Barometric Pressure
  • 3 axis Accelerometer
  • 3 axis Gyroscope
  • 3 axis Magnetometer
  • 2 push Buttons
  • 1 Luxometer (CC2650 version only)
The config node allows the user to enable/disable any of the sensors listed above. The readings from these sensors will be sent as a JSON object payload with the sensor name appended to the topic provided:
  • Humidity - { topic: [topic_prefix]/humidity , payload: { temp: 21.2, humidity: 88} }
  • Temperature - { topic: [topic_prefix]/temperature, payload: { ambient: 21.2, object: 33.0 } }
  • Barometric Pressure - { topic: [topic_prefix]/pressure, payload: { pres: 1000 } }
  • Accelerometer - { topic: [topic_prefix]/accelerometer , payload: { x:0.0, y:9.8, z:0.0 } }
  • Magnetometer - { topic: [topic_prefix]/magnetometer , payload: { x:0.0, y:0.0, z:0.0 } }
  • Gyroscope - { topic: [topic_prefix]/gyroscope , payload: { x:0.0, y:0.0, z:0.0 } }
  • Luxometer - { topic: [topic_prefix]/luxometer , payload: { lux: 212 } }
  • Buttons - { topic: [topic_prefix]/keys , payload: { left: true, right: false} }
Note: This sensorTag library only supports using 1 SensorTag at a time.
Version: 0.0.19
Updated 10 years, 2 months ago
Rating: 1.0 1
48 in the last week
  • sensorTag
  • sensortag
  • Ti CC2650
  • Ti CC2541
