node-red-node-redis 0.0.5
A Node-RED node to save data to an Redis database
npm install node-red-node-redis
A Node-RED node to save data in a Redis database.
Pre-requisite
To run this you need a local Redis server running. For details see the Redis site.
Simple node to save data in a local Redis instance
Output
A Redis output node. Options include Hash, Set, List and String.
If key is blank, the msg.topic will be used as the key.
If type is hash, msg.payload should be an object or field=value string.
Version: 0.0.5
Updated 6 years, 9 months ago
21 in the last week
  • redis out
  • redis
