node-red-node-pushover 0.3.0
A Node-RED node to send alerts via Pushover
npm install node-red-node-pushover
A Node-RED node to send alerts via Pushover.
Uses Pushover to push the msg.payload to a device that has the Pushover app installed.
Optionally uses msg.topic to set the configuration, if not already set in the properties:
  • msg.device: to set the device
  • msg.priority: to set the priority
  • msg.topic: to set the title
  • msg.attachment: to specify an image to attach to message. Either as a path as a string, or Buffer containing image as either binary or base64 encoded, or an object containing "name" and "data" properties.
  • msg.url: to add a web address
  • msg.url_title: to add a url title
  • msg.html: set to true or 1 if message is HTML formatted, see the supported tags
  • msg.sound: to set the alert sound, see the available options
  • msg.retry: to set retry interval for Emergency priority (2) messages, see priority
  • msg.expire: to set retry duration for Emergency priority (2) messages, see priority
  • msg.callback: to set callback url for Emergency priority (2) messages, see callback
  • msg.tags: to set tags for Emergency priority (2) messages, see tags
The User-key and API-token are stored in a separate credentials file.
Uses Pushover. See Pushover.net for more details.
Version: 0.3.0
Updated 2 months, 2 weeks ago
Rating: 5.0 5
147 in the last week
  • pushover
  • pushover
  • Damien Clark
