node-red-node-pusher 1.0.0
A Node-RED node to send and receive messages using Pusher.com
A Node-RED node to send and receive messages using Pusher.com.
Pre-requisites
You need a valid Pusher App key, secret and id from http://pusher.com
npm install node-red-node-pusher
Input
Pusher input mode. Use this node to subscribe to a Pusher channel/event. You need a valid Pusher App key.
The node will set msg.payload
to the message that arrives, and msg.topic
to the eventname.
Output
Pusher output node for sending messages to a specific channel/event. You need an App key, secret and ID of a Pusher app.
The node will send the msg.payload
of the incoming message.
