node-red-node-prowl 0.0.10
A Node-RED node to send alerts via Prowl
A Node-RED node to send alerts via Prowl.
npm install node-red-node-prowl
Uses Prowl to push the msg.payload
to an Apple device that has the prowl app installed.
Optionally uses msg.topic
to set the title. You can also set msg.priority
to configure the urgency from -2 (low), through 0 (normal) to 2 (urgent).
You may use msg.url
to set a url to redirect the user to on receipt of the message if you don't set one in the edit dialogue.
Uses Prowl. See this link for more details.
