node-red-node-pisrf 0.4.0
A Node-RED node for a Raspberry Pi to use a SRF04 or SRF05 range finder
npm install node-red-node-pisrf
node-red-node-pisrf
A Node-RED node for Raspberry Pi to read range from an SRF05 Ultrasonic range sensor.
Only works with a Raspberry Pi.
Raspberry Pi input from an SRF04 or SRF05 ultrasonic range finder.
The configuration requires two GPIO pin numbers, the trigger pin and the echo pin. These can be any spare valid Pi GPIO pins. e.g.
    7,11
You can also set the repeat frequency of measurements - default 0.5 seconds.
Outputs a msg.payload with a number representing the range in cm.
Produces one measure every 0.5s (by default) - but only if the distance is different from the previous reading.
Note: we are using the actual physical pin numbers on connector P1 as they are easier to locate.
Version: 0.4.0
Updated 2 years ago
Rating: 5.0 3
23 in the last week
  • rpi-srf
  • SRF04
  • SRF05
  • ultrasonic
  • range
  • HC-SR04
  • SR04
