node-red-node-pidcontrol 0.0.4
A Node-RED node that that provides a simple PID controller.
npm install node-red-node-pidcontrol
A Node-RED node that provides a simple PID controller.
    npm i node-red-node-pidcontrol
PID controller node.
This node ONLY expects a numeric msg.payload containing the current reading.
It will output the correction that needs to be applied in order to move to the preset set point value.
The damping factors are typically in the range 0 - 1. See Wikipedia for more details on PID controllers.
The set point may be overridden by msg.setpoint. If you do so the edit box value can be used as the initial value.
Version: 0.0.4
Updated 8 years, 1 month ago
15 in the last week
  • PID control
  • PID
  • control
