node-red-node-pibrella 0.1.0
A Node-RED node to read from and write to a Pibrella Raspberry Pi add-on board
A Node-RED node to control a Pibrella add-on board for a Raspberry-Pi.
npm install node-red-node-pibrella
Pre-reqs
Requires the RPi.PIO python library version 0.5.8 (or better) in order to work. See the RPi.GPIO site for mode details.
sudo apt-get -y install python-rpi.gpio
A pair of input and output Node-RED nodes for the Raspberry Pi Pibrella from Pimoroni.
Output
The output node will set the selected output high (on) or low (off) depending on the value passed in. Expects a msg.payload
with either a 0 or 1 (or true or false).
You may also select PWM mode to dim the on board LEDs if you wish. Expects a value from 0 to 100.
The Buzzer expects a number representing the frequency in Hz. 0 is off and 1 is a tone - so you can use 0/1 type inputs as well.
Input
The input node generates a msg.payload
with either a 0 or 1 depending on the state of the input pin.
The msg.topic
is set to pibrella/{the pin id} - which will be A, B, C, D or R.
