node-red-node-pi-sense-hat-simulator 0.1.0
A Node-RED node to simulate a Raspberry Pi Sense HAT
npm install node-red-node-pi-sense-hat-simulator
A node to simulate a Raspberry Pi Sense HAT.
This allows you to create flows that interact with a virtual Sense HAT without the actual hardware - whether you're running on a Raspberry Pi, a laptop or elsewhere.
Once a Sense HAT simulator node has been deployed, the web page that provides a UI to the simulator can be accessed by clicking the link in the node's info panel.
Input Node
This node sends readings from the various sensors on the Sense HAT, grouped into three sets; motion events, environment events and joystick events.
Motion events
The current version of the simulator does not support Motion events
Motion events include readings from the accelerometer, gyroscope and magnetometer, as well as the current compass heading. They are sent at a rate of approximately 10 per second. The topic is set to motion and the payload is an object with the following values:
  • acceleration.x/y/z : the acceleration intensity in Gs
  • gyroscope.x/y/z : the rotational intensity in radians/s
  • orientation.roll/pitch/yaw : the angle of the axis in degrees
  • compass : the direction of North in degrees
Environment events
Environment events include readings from the temperature, humidity and pressure sensors. They are sent at a rate of approximately 1 per second. The topic is set to environment and the payload is an object with the following values:
  • temperature : degrees Celsius
  • humidity : percentage of relative humidity
  • pressure : Millibars
Joystick events
Joystick events are sent when the Sense HAT joystick is interacted with. The topic is set to joystick and the payload is an object with the following values:
  • key : one of UP, DOWN, LEFT, RIGHT, ENTER
  • state : the state of the key:
    • 0 : the key has been released
    • 1 : the key has been pressed
    • 2 : the key is being held down
Output Node
This node sends commands to the 8x8 LED display on the Sense HAT.
Commands are sent to the node in msg.payload. Multiple commands can be sent in a single message by separating them with newline (\n) characters.
Set the colour of individual pixels
Format: <x>,<y>,<colour>
x and y must either be a value from 0 to 7, a * to indicate the entire row or column, or a range such as 3-6.
colour must be one of:
To set the entire screen to red: *,*,red
To set the four corners of the display to red, green (#00ff00), yellow and blue (0,0,255):
0,0,red,0,7,#00ff00,7,7,yellow,7,0,0,0,255
To set a 3-pixel wide column to purple: 4-6,*,purple
Rotate the screen
Format: R<angle>
angle must be 0, 90, 180 or 270.
Flip the screen
Format: R<axis>
axis must be either H or V to flip on the horizontal or vertical axis respectively.
Scroll a message
If msg.payload is not recognised as any of the above commands, it is treated as a text message to be scrolled across the screen.
If the text is a single character, it will be displayed without scrolling. To scroll a single character, append a blank space after it - "A ".
The following message properties can be used to customise the appearance:
  • msg.color - the colour of the text, default: white
  • msg.background - the colour of the background, default: off
  • msg.speed - the scroll speed. A value in the range 1 (slower) to 5 (faster), default: 3
Set the screen brightness
Format: D<level>
level must be 0 (low) or 1 (high).
Version: 0.1.0
Updated 4 years, 2 months ago
Rating: 0.0
34 in the last week
  • rpi-sensehatsim in
  • rpi-sensehatsim out
  • sensehat
  • astropi
