node-red-node-pi-neopixel 2.0.0
A Node-RED node to output to a neopixel (ws2812) string of LEDS from a Raspberry Pi.
npm install node-red-node-pi-neopixel
A Node-RED node to drive a strip of Neopixel or WS2812 LEDs from a Raspberry Pi.
Pre-requisites
The Neopixel python driver need to be pre-installed... The easiest way to get the driver installed is to use the Unicorn HAT drivers install script... see the Pimoroni Getting Started with Unicorn HAT page.
curl -sS get.pimoroni.com/unicornhat | bash
The data pin of the pixels should be connected to physical pin 12 - GPIO 18 of the Pi. Note: this may conflict with audio playback.
To set the background just set msg.payload to an html_colour name. Here is a list of html_colour names.
It also accepts a string triple rrr,ggg,bbb or #rrggbb
Bar Chart
Defaults style mode using configured foreground and background colours. The foreground colour is used to indicate the number of pixels or length required.
It accepts a number in msg.payload that can be either the number of pixels, or a percentage of the total length.
If you want to change the foreground colour, you can set msg.payload to a comma separated string of html_colour,length or length,html_colour. The foreground will then remain that colour until changed again.
Needle
It can also display a needle (single pixel) type gauge. The rest of the pixels are set to the background colour on one side, and the foreground colour on the other side of the indicated pixel.
If you want to change the needle colour, you can set msg.payload to a comma separated string of html_colour,length or length,html_colour.
Shift left and Shift right
You can also select shift modes where a single colour pixel is added to either the start or the end of the strip, shifting all the others along by one. In this mode the msg.payload can be specified as either an html colour name, an r,g,b triple or #rrggbb.
Low level "API"
The nth pixel of the string can be set by msg.payload with a CSV string n,r,g,b , where r, g and b are 0-255.
A range of pixels from position x to y can be set by msg.payload with a CSV string x,y,r,g,b
Brightness
The overall brightness of the pixels can be set to a level in the 0-100 range (0 being off, 100 being full brightness). It can also be set via msg.brightness The default level is 100 (full brightness)
Gamma correction
The node uses gamma correction to display colours as naturally as possible. This can be disabled if required. (e.g when working with low brightness levels)
Version: 2.0.0
Updated 3 years ago
Rating: 3.3 4
47 in the last week
  • rpi-neopixels
  • ws2812
  • neopixel
