node-red-node-physical-web 0.0.16
Node-RED nodes to interact with the Physical Web
npm install node-red-node-physical-web
Nodes to allow Node-RED to act as an Eddystone BLE beacon.
Prerequisites
You will need a suitable Bluetooth Low Energy (BLE) stack and drivers for your hardware
  • for example Bluez 5.2.x or better.
Raspberry Pi
Install Bluetooth drivers and bluez stack, and set executeable by non-root user
sudo apt-get install libbluetooth-dev libudev-dev pi-bluetooth
sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
Linux / OSX / Windows
Follow just the pre-reqs for noble here.
npm i node-red-node-physical-web
Then on Linux follow these instructions:
https://github.com/sandeepmistry/bleno#running-on-linux
Physical-Web Out
A node to allow Node-RED to act as an Eddystone beacon broadcasting URLs
The config window lets you set the initial URL, announcement power and period for the Eddystone.
Any messages received will update the advertised URL from the msg.payload
Physical-Web In
A node to scan for local Eddystones and output information about discovered URLs and TLM data.
Two types of messages will be emitted:
  • URL
    • type - Eddystone type
    • txPower - Received power at 0m in dBm
    • url - The URL the beacon is broadcasting
    • tlm - TLM data, if the device is interleaving broadcasts
    • rssi - RSSI of the beacon
    • distance - Estimated distance to the beacon
  • UID
    • namespace - 10-byte ID of namespace
    • instance - 6-byte ID instance
Where the tlm data will be in the following format
  • tlm
    • version - TLM version
    • vbatt - Battery Voltage
    • temp - Temperature
    • advCnt - Advertising PDU count
    • secCnt - Time since power on or reboot
Version: 0.0.16
License: APACHE-2.0
39 in the last week
  • PhysicalWeb in
  • PhysicalWeb out
  • physical-web
  • eddystone
  • beacon
  • ble
