node-red-node-openwhisk 0.3.4
A set of nodes for interacting with IBM Bluemix OpenWhisk
npm install node-red-node-openwhisk
A set of Node-RED nodes for interacting with IBM Bluemix OpenWhisk.
Run the following command in the user directory of your Node-RED install. This is usually ~/.node-red.
Service configuration
The OpenWhisk Service configuration node allows you to provide your authentication key for the service and share it with the other OpenWhisk nodes.
By default, the service node targets the IBM Bluemix OpenWhisk service, but the API URL can be overridden for when running against another instance.
Invoke a trigger
The trigger node can be used to invoke a trigger at the end of a flow.
The namespace and trigger can be configured in the node or, if left blank, provided by msg.namespace and msg.trigger respectively.
msg.payload should be an object of key-value pairs to pass to the trigger; any other type is ignored.
Create or edit a trigger
The trigger node can be used to create new triggers or modify properties for existing ones.
Fill in the service, namespace and trigger name in the edit dialog. The node will retrieve and display the current trigger properties from the OpenWhisk service.
Selecting the "Allow Edits" checkbox will allow you to modify these properties.
On deployment, the updated properties will be published to the OpenWhisk provider.
Invoke an action
The action node can be used to invoke an action and pass on the result in the flow.
The namespace and trigger can be configured in the node or, if left blank, provided by msg.namespace and msg.action respectively.
msg.payload should be an object of key-value pairs to pass to the action; any other type is ignored.
The output message contains the following properties:
  • payload is the result of the action
  • data is the complete response object
Create or edit an action
The action node can be used to create new actions or modify properties for existing ones.
Fill in the service, namespace and action name in the edit dialog. The node will retrieve and display the current action source and properties from the OpenWhisk service.
Version: 0.3.4
Updated 7 years ago
72 in the last week
  • openwhisk-service
  • openwhisk-trigger
  • openwhisk-action
  • openwhisk
  • Nick O'Leary
  • James Thomas
