node-red-node-openweathermap 1.0.1
A Node-RED node that gets the weather report from openweathermap
npm install node-red-node-openweathermap
A Node-RED node that gets the weather report and forecast from OpenWeatherMap.
Two nodes that get the weather report and forecast from OpenWeatherMap.
Note: An API key is required to use these nodes. To obtain an API key go to OpenWeatherMap.
Input Node
Fetches the current weather or 5 day forecast at a location specified by city and country or latitude and longitude every 10 minutes - and outputs a msg if something has changed.
Query node
Accepts an input to trigger fetching the current weather either from a specified city and country or latitude and longitude or passed in on
msg.location.city and msg.location.country
    or
msg.location.lat and msg.location.lon
Results
Current conditions will return
  • description - a brief verbal description of the current weather for human reading.
  • weather - a very short description of the current weather.
  • icon - the weather icon code for the current conditions.
  • id - the id given to the current weather by OpenWeatherMap
  • tempc - the current ground temperature at that location in Celsius.
  • tempk - the current ground temperature at that location in Kelvin.
  • humidity - the current relative humidity at the location in percent.
  • windspeed - the current wind speed at the location in metres per second.
  • winddirection - the current wind direction at the location in meteorological degrees.
  • location - the name of the location from which the data was sourced.
  • rain - the precipitation amount in mm/h (only present if it is raining).
5 day Forecast will return a 5 part array, each with
  • dt - epoch timestamp
  • pressure - in hPa
  • humidity - in %
  • speed - wind speed in metres per second
  • deg - wind direction in degrees
  • clouds - cloudiness in %
  • temp - an object with various temperatures in degC,
    • day, min, max, night, eve, morn
  • weather - an object with some misc. data,
    • description, icon, main, id
The node also sets the following properties of msg.location.
  • lat - the latitude of the location from which the data was sourced.
  • lon - the longitude of the location from which the data was sourced.
  • city - the city from which the data was sourced.
  • country - the country from which the data was sourced.
Finally, the node sets:
  • msg.time - the time at which the weather data was received by OpenWeatherMap.
  • msg.data - the full JSON returned by the API. This is VERY rich...
Weather data provided by OpenWeatherMap.org/
Version: 1.0.1
Updated 2 years, 5 months ago
Rating: 4.3 15
4600 in the last week
  • openweathermap
  • openweathermap in
  • weather
  • openweathermap
