node-red-node-msgpack 1.2.1
A Node-RED node to pack and unpack objects to msgpack format
npm install node-red-node-msgpack
A Node-RED node to pack and unpack objects to msgpack format buffers.
Changes
Version 1.0.0 - move to msgpack-lite library (more supported and faster) - This uses the more recent msgpack specification so please ensure all your endpoints are also using the latest spec.
Uses the msgpack-lite npm to pack and unpack msg.payload objects to msgpack format buffers.
Note: this node does not currently encode raw buffer types. It will automatically try to decode any buffer received, and may not cause an error.
If the input is NOT a buffer it converts it into a msgpack buffer.
If the input is a msgpack buffer it converts it back to the original type.
Version: 1.2.1
Updated 4 years, 6 months ago
143 in the last week
  • msgpack
  • msgpack
