node-red-node-mongodb 0.2.5
Node-RED nodes to talk to a Mongo database
npm install node-red-node-mongodb
A Node-RED node to save data in a MongoDB database.
Note : This is the same node as was in the core of Node-RED. As of v0.10.8 you will need to install it from here if still required.
Pre-requisite
To run this you need a local MongoDB server running. For details see the MongoDB site.
Note that this package requires a MongoDB client package at least version 3.6.3 - if you have an older (version 2) client, you may need to remove that before installing this
        npm remove mongodb
Nodes to save and retrieve data in a MongoDB instance - the database server can be local (mongodb//:localhost:27017), remote (mongodb://hostname.network:27017), replica-set or cluster (mongodb://hostnameA.network:27017,hostnameB.network:27017), and DNS seedlist cluster (mongodb+srv://clustername.network).
Reference MongoDB docs to see which connection method (host or clustered) to use for your MongoDB instance.
Input
Calls a MongoDB collection method based on the selected operator.
Find queries a collection using the msg.payload as the query statement as per the .find() function.
Optionally, you may also (via a function) set
  • a msg.projection object to constrain the returned fields,
  • a msg.sort object,
  • a msg.limit number,
  • a msg.skip number.
Count returns a count of the number of documents in a collection or matching a query using the msg.payload as the query statement.
Aggregate provides access to the aggregation pipeline using the msg.payload as the pipeline array.
You can either set the collection method in the node config or on msg.collection. Setting it in the node will override msg.collection.
See the MongoDB collection methods docs for examples.
The result is returned in msg.payload.
Output
A simple MongoDB output node. Can save, insert, update and remove objects from a chosen collection.
MongoDB only accepts objects.
Save and insert can either store msg or msg.payload. If msg.payload is selected it should contain an object. If not it will be wrapped in an object with a name of payload.
Save will update an existing object or insert a new object if one does not already exist.
Insert will insert a new object.
Update will modify an existing object or objects. The query to select objects to update uses msg.query and the update to the element uses msg.payload. Update can add an object if it does not exist or update multiple objects.
Remove will remove objects that match the query passed in on msg.payload. A blank query will delete all of the objects in the collection.
By default MongoDB creates an msg._id property as the primary key - so repeated injections of the same msg will result in many database entries. If this is NOT the desired behaviour - ie. you want repeated entries to overwrite, then you must set the msg._id property to be a constant by the use of a previous function node. This must be done at the correct level. If only writing msg.payload then payload must contain the _id property. If writing the whole msg object then it must contain an _id property.
This could be a unique constant or you could create one based on some other msg property.
Currently we do not limit or cap the collection size at all...
Version: 0.2.5
Updated 6 years, 2 months ago
Rating: 4.5 8
308 in the last week
  • mongodb
  • mongodb out
  • mongodb in
  • mongodb
  • Ross Cruickshank
