node-red-node-intel-gpio 0.4.0
A Node-RED node to talk to an Intel Galileo, Edison or Siemens IOT2050 board using mraa
npm install node-red-node-intel-gpio
A Node-RED node to talk to an Intel Galileo or Edison running mraa.
    npm i node-red-node-intel-gpio
The Galileo or Edison must already be running Linux, and have Node-RED installed.
See the Intel Downloads for hardware / downloads for your particular board.
Ensure the latest version of mraa libraries are installed: (version 1.5 as of Sept 2015)
    echo "src mraa-upm http://iotdk.intel.com/repos/1.5/intelgalactic" > /etc/opkg/mraa-upm.conf
    opkg update
    opkg upgrade
NOTE : This node assumes that the mraa npm is already installed globally - as it is on the Galileo and Edison boards.
If you do need to install Node-RED, you can do this as follows from the home directory of the root user
    npm install -g --unsafe-perm node-red
    mkdir .node-red
    cd .node-red
Analogue Input Node
Monitors the selected pin for changes. It outputs on a change of value. As analogue inputs are continuously changing you can set the sample rate in ms from 20 to 65535.
Digital Input Node
Monitors the selected pin for changes. It only outputs on a change of value.
Digital Output Node
Sets the selected digital pin output high or low depending on the value of msg.payload - expects a number or string 0 or 1.
Pulse Width Modulation (PWM) Node
The msg.payload should contain a floating point number value between 0 (off) and 1 (fully on), or a string representation thereof.
You can set the overall period (mS) in the edit dialogue.
For servo control set the period to 20mS and vary the input between 0.05 and 0.10,
    0.05 = 5% of 20mS = 1mS
    0.75 = 7.5% of 20mS = 1.5mS - typical servo centre point
    0.10 = 10% of 20mS = 2mS
Example
Simple flow to blink Pin 13
...tbd
Version: 0.4.0
Updated 3 years ago
37 in the last week
  • mraa-gpio-ain
  • mraa-gpio-din
  • mraa-gpio-dout
  • mraa-gpio-pwm
  • mraa-gpio-led
  • intel
  • galileo
  • edison
  • siemens
  • iot2050
  • @fr0st61te
  • @jan-kiszka
