node-red-node-firebird 0.0.3
A Node-RED node to read and write to a Firebird database
A Node-RED node to read and write to a Firebird database.
npm install node-red-node-firebird
Allows basic access to a Firebird database.
This node uses the query operation against the configured database. This does allow both INSERTS and DELETES.
By it's very nature it allows SQL injection... so be careful out there...
The msg.topic
must hold the query for the database, and the result is returned in msg.payload
Typically the returned payload will be an array of the result rows.
If nothing is found for the key then null is returned.
