node-red-node-dweetio 0.0.15
A Node-RED node to send and receive simple dweets
npm install node-red-node-dweetio
A Node-RED node to send and receive simple dweets.
This node does NOT support private or "locked" dweets.
Output
Sends the msg.payload to Dweet.io
Optionally uses msg.thing to set the thing id, if not already set in the properties.
You need to make the thing id unique - you are recommended to use a GUID.
Input
Listens for messages from Dweet.io
The thing id should be globally unique as they are all public - you are recommended to use a GUID.
The Thing ID is set into msg.dweet, and the timesamp into msg.created.
For further info see the Dweet.io website
Sample Flow
Cut the text below - then in Node-RED use Ctrl-I (Import) - Ctrl-V (Paste) to insert into your workspace.
[{"id":"58bfbfe.fa7404","type":"debug","name":"","active":true,"console":"false","complete":"false","x":401,"y":211,"z":"8f1399c1.70ec68","wires":[]},{"id":"bc69a077.43966","type":"dweetio out","thing":"not-very-random-big-string","name":"","x":409,"y":135,"z":"8f1399c1.70ec68","wires":[]},{"id":"aaad178a.5552e8","type":"dweetio in","thing":"not-very-random-big-string","name":"","x":153,"y":211,"z":"8f1399c1.70ec68","wires":[["58bfbfe.fa7404"]]},{"id":"db15a21f.24ea6","type":"inject","name":"","topic":"Ticktock","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":160,"y":136,"z":"8f1399c1.70ec68","wires":[["bc69a077.43966"]]}]
Version: 0.0.15
Updated 10 years, 1 month ago
17 in the last week
  • dweetio out
  • dweetio in
  • dweetio
