node-red-node-data-generator 1.0.2
A Node-RED node to create a string of dummy data values from a template. Useful for test-cases.
npm install node-red-node-data-generator
A Node-RED node to create dummy data values from a template. Useful for building test-cases.
Either use the Manage Palette option in the Node-RED Editor menu, or run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-node-data-generator
Creates dummy data based on a handlebars-style template.
Uses the dummy-json module, which can create rich sets of dummy data for testing or other uses.
It will build a string, or a parsed JSON object, creating values based on the helper names below:
title, firstName, lastName, company, domain, tld, email,
street, city, country, countryCode, zipcode, postcode,
lat, long, phone "+xx (x) xxxx xxx xxx", color, hexColor, guid,
ipv4, ipv6, lorem nn, date, time,
lowercase (helper), uppercase (helper), int, float, boolean
Multiple values can be generated by use of the repeat syntax.
In addition any properties passed in on the msg object can also be used - for example {{payload}}.
Finally msg.seed can be used to preset the pseudo-random seed to ensure repeatability across calls.
Example
The example flow below produces a JSON string which is then converted into an object, for example:
    "name": "Theo Cumbie",
    "work": "CoreXTS",
    "email": "[email protected]",
    "address": "83 Sherman Road",
    "country": "Angola",
    "text": "Sagittis orci elementum e vel scelerisque. Amet ac tristique lectus. Morbi e suscipit scelerisque auctor curabitur velit metus gravida quis."
Example flow
[{"id":"325b6a4a.cf1706","type":"inject","z":"4affede3.af6f44","name":"","topic":"","payload":"","payloadType":"str","repeat":"","crontab":"","once":false,"x":110,"y":300,"wires":[["9d14acc0.c8d9d"]]},{"id":"96c9a04e.35232","type":"debug","z":"4affede3.af6f44","name":"","active":true,"console":"false","complete":"false","x":513,"y":300,"wires":[]},{"id":"9d14acc0.c8d9d","type":"data-generator","z":"4affede3.af6f44","name":"","field":"payload","fieldType":"msg","syntax":"json","template":"{\n "name": "{{firstName}} {{lastName}}",\n "work": "{{company}}",\n "email": "{{email}}",\n "address": "{{int 1 100}} {{street}}",\n "country": "{{country}}",\n "countryCode": "{{countryCode}}",\n "text":"{{lorem 20}}"\n}","x":280,"y":300,"wires":[["96c9a04e.35232"]]}]
Version: 1.0.2
Updated 7 months, 2 weeks ago
66 in the last week
  • data-generator
  • data-generator
  • dummy-json
