node-red-node-cf-cloudant 0.2.17
A Node-RED node to access Cloudant and couchdb databases
npm install node-red-node-cf-cloudant
A pair of Node-RED nodes to work with documents in a Cloudant database that is integrated with IBM Bluemix.
Install from npm
Allows basic access to a Cloudant database to insert, update, delete and search for documents.
To insert a new document into the database you have the option to store the entire msg object or just the msg.payload. If the input value is not in JSON format, it will be transformed before being stored.
For update and delete, you must pass the _id and the _revas part of the input msg object.
To search for a document you have two options: get a document directly by its _id or use an existing search index from the database. For both cases, the query should be passed in the msg.payload input object as a string.
When getting documents by id, the payload will be the desired _id value. For search indexes, the query should follow the format indexName:value.
Authors
Version: 0.2.17
Updated 10 years, 10 months ago
75 in the last week
  • cloudant
  • cloudant out
  • cloudant in
  • cloudant
  • couchdb
  • bluemix
  • Túlio Pascoal
  • Igor Leão
