node-red-node-ademco 0.1.0
A Node-RED node to Parse Ademco Panel Messages.
Two nodes used to work with the AD2USB Data stream either from a Serial Node or MQTT message.
$ npm i node-red-node-ademco
Documentation
AdemcoListener Node:
Parses the panel messages from the NuTech AD2USB via a serial port input node or MQTT node, converts it into a JavaScript object and either reports partition state changes or every input message; as defined in the node configuration, into the JavaScript object specified below.
partitionState ={
partitionNumber : 1, // Indicates the Partition ID
messageLine1 : "", // Alpha panel Message Line 1
messageLine2 : "", // Alpha panel Message Line 2
lastUpdated : null, // DateTime the message was parsed
systemState : AlarmStateEnum.NOT_READY, // StateMachinable value, see System State object
lastTransitionDate : null, // Prior State Change DateTime
lastSystemState : AlarmStateEnum.NOT_READY, // Prior StateMachinable value, see System State object
panels : [], // List of Panel IDs this message is ment for
zoneFaults : [], // List of faulted Zones (Not Working)
partitionReady : false, // Indicates the Partition is ready to arm (No Faults)
partitionArmedAway : false, // Indicates the Partition is Armed Away ( Motion Detection == Instant Alarm )
partitionArmedStay : false, // Indicates the Partition is Armed Stay ( Motion Detection Zones disabled )
backlight : false, // Panel Backlight should be lit
programmingMode : false, // Indicates System is in Programming Mode
beepCount : 0, // Indicates Panel should beep x times
zoneBypass : false, // Indicates one or more zones bypassed on partition
linePower : false, // Indicates System is on AC Power
chimeEnabled : false, // Indicates Panel should chime when Zones are faulted in Disarmed State
alarmOccurred : false, // Indicates an alarm has been triggered (Could be Silent Alarm!)
alarmSounding : false, // Indicates the Alarm Siren is triggered
batteryLow : false, // Indicates the Backup Battery is Low/not charging
delayOff : false, // Indicates the System is Armed Instant ( AKA Night Mode )
fireAlarm : false, // Indicates the Fire Zones have been triggered
zoneFaulted : false, // Indicates one or more Zones are faulted
perimeterOnly : false, // Indicates non-motion zones are armed
stateChange : false // Indicates the Primary Arming state has changed
The Partition state Enum Values:
var AlarmStateEnum = {
DISARMED : 0, // Partition is in an unknown state or initialized
NOT_READY : 1, // Partition is Disarmed but but not ready to arm (One or more Faults)
READY : 2, // Partition is Disarmed but ready to arm (No Faults)
ARMED_AWAY : 3, // Partition is Armed Away, Motion Detection active
ARMED_STAY : 4, // Partition is Armed Stat, Motion Detection not active
ARMED_INSTANT : 5, // Partition is Armed Instant, Motion Detection not active (No Entry Delay)
ALARM : 6, // Partition is in a Faulted Alarm State
FIRE_ALARM : 7 // Partition is in a Faulted Fire Alarm State
AdemcoStatus Node:
Using the current panel message state from the Listener Node, this will either use the message.partion == Partition Number or the Node Configuration to export the current partition state on the output message.payload. Use this node to query the current alarm panel state(s).
Example Flow
[{"id":"a019b186.5fe65","type":"AdemcoStatus","name":"","partition":"2","x":561,"y":426,"z":"88661d46.7799e","wires":[["a328679e.5cd798"]]},{"id":"a328679e.5cd798","type":"debug","name":"","active":true,"console":"false","complete":"true","x":726,"y":425,"z":"88661d46.7799e","wires":[]},{"id":"373bc3f2.c8c43c","type":"inject","name":"","topic":"","payload":"partition","payloadType":"date","repeat":"","crontab":"","once":false,"x":175,"y":425,"z":"88661d46.7799e","wires":[["6f7f728.f90808c"]]},{"id":"6f7f728.f90808c","type":"change","action":"replace","property":"partition","from":"","to":"1","reg":false,"name":"","x":349,"y":425,"z":"88661d46.7799e","wires":[["a019b186.5fe65"]]}]
If you have any questions, just open an issue.
To order a AD2USB Module for your Ademco Alarm Panel
And the Protocol/Strings exported from the Panel
Example Function
Example Nod-Red 'function' that formats Partition State Messages, and routes them according to importance:
var partition = msg.payload;
if( partition !== undefined ) {
var alarmText = "";
// Format for core alarm State
alarmText += "Partition ";
alarmText += partition.partitionNumber;
alarmText += " is ";
switch ( partition.systemState ) {
case 0:
alarmText += "DISARMED";
break;
case 1:
alarmText += "NOT READY";
break;
case 2:
alarmText += "DISARMED READY";
break;
case 3:
alarmText += "ARMED AWAY";
break;
case 4:
alarmText += "ARMED STAY";
break;
case 5:
alarmText += "ARMED INSTANT";
break;
case 6:
alarmText += "ALARM";
break;
case 7:
alarmText += "FIRE ALARM";
break;
default:
alarmText += "UNKNOWN";
break;
// Format for Alarms and Faults
if( partition.systemState >= 6 || partition.systemState == 1 ) {
alarmText += "; ";
alarmText += partition.messageLine1.trim();
alarmText += " ";
alarmText += partition.messageLine2.trim();
msg.payload = alarmText;
// Route the Messages to the correct output
// Critical Events are Sent on Output 2
if( partition.systemState > 2 ) {
return [ null, msg ];
} else {
// Status Events are sent on Output 1
if ( partition.systemState == 2 && partition.lastSystemState > 2 ) {
// Unless it's transition from Higher States to Ready/Disarmed
} else {
// Non Critical Events are Sent on Output 1
return [ msg, null ];
// Fail to parse, return nothing
return [null, null];
