node-red-grovepi-nodes 0.0.3
Node-RED nodes to control GrovePi+ sensors.
npm install node-red-grovepi-nodes
Node-RED nodes to control GrovePi+ Starter Kit sensors for Raspberry Pi.
Install via npm
Run the following command in the root directory of your Node-RED install or home directory (usually ~/.node-red)
After installing this package and running Node-RED, the GrovePi+ sensors and actuators will be available in your Node-RED environment. Connect your sensor to the GrovePi board, select the port number on the node and deploy your flow.
Sensors
Every sensor that comes with the GrovePi+ Starter Kit is supported. These sensors are:
  • Buzzer
  • Button
  • LED (red, green & blue)
  • Sound
  • Relay
  • Ultrasonic Ranger
  • Temperature Humidity
  • Rotary Angle
  • RGB Backlit LCD
  • Light
Version: 0.0.3
Updated 9 years, 11 months ago
8 in the last week
  • grovepi-led
  • grovepi-relay
  • grovepi-buzzer
  • grovepi-lcd-rgb
  • grovepi-ultrasonic
  • grovepi-rotary
  • grovepi-light
  • grovepi-button
  • grovepi-sound
  • grovepi-temperature
  • grovepi
