node-red-flowbasket 0.0.4
A Node-RED node to backup/restore the node-red-flow to/from Cloudant
npm install node-red-flowbasket
A Node-RED node to backup/restore the node-red-flow to/from Cloudant.
Mainly assumes the running at Node-RED on the IBM Bluemix.
How to Install
How to Use
Preparations are necessary as follows before using Node
  1. To create a Cloudant service
  2. To create a DB to back up the flow
  3. To create a following of Search Index SearchIndes
toBackup Node settings are as follows:
  • SourceCloudant : To set up the connection information of CloudantDB the various settings of the Node-RED has been stored
  • TargetCloudant : To set the connection information for CloudantDB to back up the Flow
  • AppName : To set the Node-RED application name to back up the Flow
  • TargetDB : To set the CloudantDB name to back up the Flow
toRestore Node settings are as follows:
  • RestoreCloudant : To set up the connection information of CloudantDB the various settings of the Node-RED has been stored
  • BackupCloudant : To set the connection information for CloudantDB to back up the Flow
  • BackupDB : To set the CloudantDB name to back up the Flow
Copyright (c) 2016 Kota Suizu
Released under the MIT license
http://opensource.org/licenses/mit-license.php
Version: 0.0.4
Updated 8 years, 3 months ago
6 in the last week
  • flowbasket-config
  • FlowBasket toBackup
  • FlowBasket toRestore
  • cloudant
  • backup
  • restore
  • bluemix
