node-red-contribe-xbee-api 0.1.1
Node-RED nodes to talk to xbee (API Mode)
npm install node-red-contribe-xbee-api
Node-RED nodes to talk to xbee (API Mode).
    npm i node-red-contribe-xbee-api
For versions on node.js prior to 4.x (ie v0.10.x and v0.12.x) please install using
    sudo npm i -g [email protected]
During install there may be multiple messages about optional compilation. These may look like failures... as they report as failure to compile errors - but often are warnings and the node will continue to install and, assuming nothing else failed, you should be able to use it. Occasionally some platforms will require you to install the full set of tools in order to compile the underlying package.
Provides two nodes - one to receive messages, and one to send.
Input
Reads data from msg.payload and parse them into Frames. It then outputs msg.payload as either a Frame Object.
Output
Reads data from msg.payload as a Frame Object and parse them into msg.payload as raw.
Only the msg.payload is sent.
Version: 0.1.1
Updated 7 years, 8 months ago
1 in the last week
  • xbeeapi in
  • xbeeapi out
  • xbeeapi-config
  • xbee api
