node-red-contrib-zip 1.1.0
Node-RED node to create and read ZIP files
npm install node-red-contrib-zip
Node-RED node to create and read ZIP files. Based on jszip
A function that parses the msg.payload to convert a Buffer to/from a ZIP object. Places the result back into the payload.
If Mode is Compress, the output is always a Buffer with a ZIP content, and the input payload can be one of the following:
  • Buffer/String: The payload is compressed as a single file in the resulting ZIP. The Filename specifies the name of this file, or can be specified with msg.filename if the configuration is left empty
  • Array: An array of objects containing filename as a String and payload as a Buffer/String, each representing one file in the resultiing zip
If Mode is Decompress, the input payload is expected to be a Buffer, and the output is an Array with objects containing filename as a String and payload as a Buffer
Copyright 2017-2020 Guilherme Francescon Cittolin, Apache 2.0 license.
Version: 1.1.0
Updated 3 years, 7 months ago
Rating: 5.0 3
295 in the last week
  • zip
  • zip
  • unzip
