node-red-contrib-zibase 0.1.6
A Node Red Input Node that reads all events from Zibase
npm install node-red-contrib-zibase
Input Node for NODE-RED which will configure itself to listen on UDP port for all Zibase events. Uses ZAPI 1, cf http://www.zodianet.com/zapi.html
Works only if Node-Red server runs on same network as Zibase. Make sure your Node-Red server firewall allows incoming UDP packets on port 17100 !
You only need to configure local IP address of Zibase box.
Puts the received messages in msg.payload
Parses additional info such as :
  • msg.id
  • msg.level
  • msg.temperature
  • msg.humidity
  • msg.rf
  • msg.device
Only tested on ZIBASE Classic : http://www.zodianet.com/toolbox-zibase/zibase-classic.html
Version: 0.1.6
Updated 9 years, 9 months ago
8 in the last week
  • Zibase
  • zibase
