node-red-contrib-zeromq 0.0.3
Node-RED nodes that provides a pair of ZeroMQ publish and subscribe nodes.
npm install node-red-contrib-zeromq
Node-RED nodes that provide a pair of publish subscribe or push pull nodes for ZeroMQ.
Provides a peer-to-peer publish subscribe capability, not unlike MQTT, but without a broker, and without many of the same semantics. Works nicely using localhost to provide local process separation. Also support push pull mode of connection.
Relies on the zeromq npm package to provide pre-build binaries to make installing easier... but can take some time to compile if not available.
Input
The host should be specified as a ZeroMQ connection string. This is typically of the form tcp://ip.address.of.server:port
When subscribing a topic of interest can be specified by a string. The topic matching is purely on first matching characters - i.e. the topic starts with...
Note: this is NOT the same as MQTT - please read up on how ZeroMQ handles topics before raising an issue.
ZeroMQ messages can have multiple parts or fields - typically two - by default topic and payload, but you can name more if required depending upon the application you are trying to integrate, by using the comma separated field property.
Output
The host should be specified as a ZeroMQ connection string. This is typically of the form tcp://*:port
By default this node expects to publish or push two fields - msg.topic and msg.payload. However ZeroMQ can support multipart messages and the msg properties to send can be specified by the comma separated fields configuration.
The topic to send can be fixed in the configuration if required.
Request
A node to handle ZeroMQ pair, request and response messaging modes.
The host should be specified as a ZeroMQ connection string. This is typically of the form 'tcp://ip.address.of.host:port'
ZeroMQ can support multipart messages and extra 'msg' properties to send can be specified by the comma separated fields configuration.
Version: 0.0.3
Updated 2 weeks, 5 days ago
0 in the last day
3 in the last week
131 in the last month
  • zeromq in
  • zeromq out
  • zeromq request
  • zeromq
  • zmq
  • 0mq
  • publish
  • subscribe
  • pubsub
  • dceejay
