node-red-contrib-yoctopuce-sensors 1.0.4
A Node-RED node to interact with Yoctopuce sensors.
npm install node-red-contrib-yoctopuce-sensors
A Node-RED node to interact with Yoctopuce Sensors.
You can install this node directly from the "Manage Palette" menu in the Node-RED interface. There are no external dependencies or compilation steps.
Alternatively, run the following command in your Node-RED user directory - typically ~/.node-red on Linux or %HOMEPATH%\.nodered on Windows
Each connection to a Yoctopuce sensor is represented by a YSensor node.
The YSensor node has 6 parameters:
  • YoctoHub Hostname: the hostname or the IP address of the VirtualHub or YoctoHub where the YSensor is connected.
  • YoctoHub Port: the port used by the VirtualHub or YoctoHub (usually 4444).
  • YoctoHub Username (optional): the username to access the VirtualHub or YoctoHub.
  • YoctoHub Password (optional): the password to access the VirtualHub or YoctoHub.
  • YSensor Hardware ID: the hardware id of the Yoctopuce sensor.The Hardware ID can be specified using several formats:
    • FunctionLogicalName
    • ModuleSerialNumber.FunctionIdentifier
    • ModuleSerialNumber.FunctionLogicalName
    • ModuleLogicalName.FunctionIdentifier
    • ModuleLogicalName.FunctionLogicalName
  • Name (optional): the name of this Node-RED node.
Version: 1.0.4
Updated 4 months ago
0 in the last day
7 in the last week
42 in the last month
  • yoctopuce-sensor
  • yoctopuce
