node-red-contrib-xml-validate 0.1.5
Node-RED node node to validate xml content using xsd-schema-validator.
Node-Red node to validate xml content using xsd-schema-validator.
This node check if xml content in msg.payload is valid according the xsd schema provided. After validate, the xml content is redirect to one of the 2 outputs available based on validation results. The first one outputs only valid xml content and the second one outputs only invalid xml content. The 3rd output outputs only xml validation error messages.
#Install
npm install node-red-contrib-xml-validate
#Nodes
###Example 1: load xml from file
[{"id":"9d25497d.63e3e8","type":"xml-validate","z":"e6defec6.66bc2","name":"validate schema from file \"people.xsd\"","filename":"node_modules\\node-red-contrib-xml-validate\\people.xsd","x":677,"y":259,"wires":[["3c05fbc3.d6cca4"],["dde5ae24.4474a"],["63f3c37a.94c41c"]]},{"id":"3c05fbc3.d6cca4","type":"debug","z":"e6defec6.66bc2","name":"valid xml","active":true,"console":"false","complete":"payload","x":1027,"y":199,"wires":[]},{"id":"63f3c37a.94c41c","type":"debug","z":"e6defec6.66bc2","name":"error results","active":true,"console":"false","complete":"payload","x":1037,"y":319,"wires":[]},{"id":"8c9d41f8.0aa28","type":"inject","z":"e6defec6.66bc2","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":97,"y":99,"wires":[["62aac75a.c0baf8"]]},{"id":"62aac75a.c0baf8","type":"file in","z":"e6defec6.66bc2","name":"from xml file \"people.xml\"","filename":"node_modules\\node-red-contrib-xml-validate\\people.xml","format":"utf8","x":337,"y":179,"wires":[["9d25497d.63e3e8"]]},{"id":"dde5ae24.4474a","type":"debug","z":"e6defec6.66bc2","name":"invalid xml","active":true,"console":"false","complete":"true","x":1037,"y":259,"wires":[]}]
###Example 2: inject xml string
[{"id":"2e6cd596.df3dca","type":"xml-validate","z":"e6defec6.66bc2","name":"","filename":"node_modules\\node-red-contrib-xml-validate\\pet.xsd","x":610,"y":615,"wires":[["5765c4e.840c63c"],["b18f315e.3f49f"],["2a40200a.a8fc6"]]},{"id":"5765c4e.840c63c","type":"debug","z":"e6defec6.66bc2","name":"this xml is valid","active":true,"console":"false","complete":"payload","x":880,"y":555,"wires":[]},{"id":"202f02bf.1751ce","type":"inject","z":"e6defec6.66bc2","name":"xml snippet","topic":"","payload":"<?xml version=\"1.0\"?> <pet><name>Tom</name></pet>","payloadType":"str","repeat":"","crontab":"","once":false,"x":350,"y":615,"wires":[["2e6cd596.df3dca"]]},{"id":"b18f315e.3f49f","type":"debug","z":"e6defec6.66bc2","name":"this xml is not valid","active":true,"console":"false","complete":"payload","x":890,"y":615,"wires":[]},{"id":"2a40200a.a8fc6","type":"debug","z":"e6defec6.66bc2","name":"validation errors","active":true,"console":"false","complete":"payload","x":880,"y":675,"wires":[]}]
###Example 3: a more complex example, validate xml in cascade.
[{"id":"7762f7b8.89c388","type":"xml-validate","z":"b85a5dfb.2ea4e","name":"validate schema from file \"people.xsd\"","filename":"node_modules\\node-red-contrib-xml-validate\\people.xsd","x":550,"y":1160,"wires":[["fb420bb6.8e03b8"],["471db0c2.b9ef8"],["a96f46f0.10b888"]]},{"id":"fb420bb6.8e03b8","type":"debug","z":"b85a5dfb.2ea4e","name":"valid xml","active":true,"console":"false","complete":"payload","x":1160,"y":980,"wires":[]},{"id":"a96f46f0.10b888","type":"debug","z":"b85a5dfb.2ea4e","name":"error results","active":true,"console":"false","complete":"true","x":1170,"y":1340,"wires":[]},{"id":"88bbf37a.7cae3","type":"inject","z":"b85a5dfb.2ea4e","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"x":130,"y":900,"wires":[["556e0b3e.ee5744"]]},{"id":"556e0b3e.ee5744","type":"file in","z":"b85a5dfb.2ea4e","name":"from xml file \"note.xml\"","filename":"node_modules\\node-red-contrib-xml-validate\\note.xml","format":"utf8","x":250,"y":1040,"wires":[["7762f7b8.89c388"]]},{"id":"8bf2789.22e1b88","type":"debug","z":"b85a5dfb.2ea4e","name":"certainly invalid xml","active":true,"console":"false","complete":"true","x":1190,"y":1160,"wires":[]},{"id":"471db0c2.b9ef8","type":"xml-validate","z":"b85a5dfb.2ea4e","name":"try another schema","filename":"node_modules\\node-red-contrib-xml-validate\\note.xsd","x":910,"y":1160,"wires":[["fb420bb6.8e03b8"],["8bf2789.22e1b88"],["a96f46f0.10b888"]]}]
###Example 4: discovery the xml type
[{"id":"3f95e2b5.78a8ee","type":"xml-validate","z":"b85a5dfb.2ea4e","name":"check for people.xsd","filename":"node_modules\\node-red-contrib-xml-validate\\people.xsd","x":500,"y":1760,"wires":[["997a9ef1.0ffad"],["1848cabd.a06ec5"],["86c55fe5.e93f7"]]},{"id":"997a9ef1.0ffad","type":"debug","z":"b85a5dfb.2ea4e","name":"its a xml of type \"people\"","active":true,"console":"false","complete":"payload","x":790,"y":1660,"wires":[]},{"id":"86c55fe5.e93f7","type":"debug","z":"b85a5dfb.2ea4e","name":"error results","active":true,"console":"false","complete":"true","x":990,"y":1900,"wires":[]},{"id":"5dec8101.e932d","type":"inject","z":"b85a5dfb.2ea4e","name":"inject valid xml","topic":"","payload":"<?xml version=\"1.0\"?> <pet><name>Tom</name></pet>","payloadType":"str","repeat":"","crontab":"","once":false,"x":260,"y":1660,"wires":[["3f95e2b5.78a8ee"]]},{"id":"b4f9c76f.acab28","type":"debug","z":"b85a5dfb.2ea4e","name":"its a xml of type \"note\"","active":true,"console":"false","complete":"true","x":1060,"y":1720,"wires":[]},{"id":"1848cabd.a06ec5","type":"xml-validate","z":"b85a5dfb.2ea4e","name":"check for note.xsd","filename":"node_modules\\node-red-contrib-xml-validate\\note.xsd","x":770,"y":1760,"wires":[["b4f9c76f.acab28"],["626ef524.98908c"],["86c55fe5.e93f7"]]},{"id":"626ef524.98908c","type":"xml-validate","z":"b85a5dfb.2ea4e","name":"check just a well formed xml","filename":"node_modules\\node-red-contrib-xml-validate\\pet.xsd","x":1080,"y":1800,"wires":[["85f3937.5be287"],[],["312ff3d.c30c70c"]]},{"id":"85f3937.5be287","type":"debug","z":"b85a5dfb.2ea4e","name":"xml of type 'unknow'","active":true,"console":"false","complete":"true","x":1360,"y":1720,"wires":[]},{"id":"312ff3d.c30c70c","type":"debug","z":"b85a5dfb.2ea4e","name":"this is not a valid xml","active":true,"console":"false","complete":"true","x":1360,"y":1860,"wires":[]}]
#Author
