node-red-contrib-wit-ai 1.0.1
Node RED Wit.ai integration
Node-RED nodes to integrate with Wit.ai.
npm install node-red-contrib-wit-ai
Make sure you have an account and an app at https://wit.ai/. You will need the Server Access Token
that can be found in the Settings menu of your Wit.ai app.
Wit.ai API conformance
20160330
https://wit.ai/docs/http/20160330
Provides these nodes:
Note: One each of Merge, Say and Error are required to be in the flow. Also, one Action node for each defined action is required.
Wit Message
Takes a sentence and returns the meaning.
Expects the payload
to be a String
Uses wit.ai's /message
endpoint.
Does not yet support the context
, msg_id
, thread_id
, and n
parameters.
Wit Converse
This is the node where you send a question or statement to your Wit.ai bot. Typically you would hook this up to a messaging app like Slack or Facebook Messanger.
You can provide a sessionId
and a context
along with the payload
. If not, they will be created for you.
After the Converse node has been given a message, the Merge, Action and Say nodes will trigger.
Wit Merge
For each configured Wit.ai bot you must provide one single Merge node. After a message has been sent to the bots Converse node, the Merge node will trigger and send a message with a context
and entities
Attach a Function node to the merge node and modify the provided context
depending on the recieved entities
The Function node must then send the message along to a Response node configured for the same Wit.ai bot as the Merge node where the message originated.
Its best if you keep the same msg
object through your flow, so to not loose any meta information stored by the Wit.ai bot.
Wit Action
If you have configured an action in any of your Wit.ai stories, you need to create an Action node in your flow with the same action name.
This node will be triggered if the conversation identifies this action.
Like the Merge node, you should let the message from an Action node continue to a Response node. Modify the msg
object, but don't replace it.
You can only have one Action node for each action on a bot.
Wit Response
A Response node takes the message from a Merge or Action node and makes sure the conversation continues.
Wit Say
The Say node is triggered when the bot has something to say. Typically you would forward the payload
to a messaging system like Slack or Facebook Messanger.
Wit Error
The Error node outputs any errors that was enconuntered during the conversation. This could be forwarded to a messaging system.
Sample Flow
[{"id":"b96f8db7.46907","type":"mqtt-broker","z":"","broker":"mybroker.com","port":"1883","clientid":"","usetls":false,"verifyservercert":false,"compatmode":true,"keepalive":"15","cleansession":true,"willTopic":"","willQos":"0","willRetain":"true","willPayload":"","birthTopic":"","birthQos":"0","birthRetain":"true","birthPayload":""},{"id":"33013393.ccfecc","type":"wit-app","z":"a14acd95.5eb53","name":"My Wit App","token":"my-witt-app-token"},{"id":"bdde0b8.f4221f8","type":"slack-bot-controller","z":"","name":"My Slack Bot","token":"my-slack-bot-token"},{"id":"c4e09a4c.3b1f68","type":"slack-in","z":"a14acd95.5eb53","name":"Slack in","events":"direct_mention,direct_message","controller":"bdde0b8.f4221f8","x":223,"y":135,"wires":[["62b96ee1.9d469"]]},{"id":"4355ed9b.bcaa14","type":"wit-converse","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":611.5,"y":136,"wires":[]},{"id":"d9fa59ab.2605a8","type":"wit-merge","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":227.5,"y":352,"wires":[["200549fb.dffab6"]]},{"id":"200549fb.dffab6","type":"function","z":"a14acd95.5eb53","name":"Merge entities and context","func":"const firstEntityValue = (entities, entity) => {\n const val = entities && entities[entity] &&\n Array.isArray(entities[entity]) &&\n entities[entity].length > 0 &&\n entities[entity][0].value\n ;\n if (!val) {\n return null;\n }\n return typeof val === 'object' ? val.value : val;\n};\n\nconst intent = firstEntityValue(msg.entities, 'intent');\nif(intent) msg.context.intent = intent;\nconst on_off = firstEntityValue(msg.entities, 'on_off');\nif(on_off) msg.context.on_off = on_off;\nconst light_description = firstEntityValue(msg.entities, 'light_description');\nif(light_description) msg.context.light_description = light_description;\n\nreturn msg;","outputs":1,"noerr":0,"x":427.5,"y":352,"wires":[["3059da01.cfa626"]]},{"id":"3059da01.cfa626","type":"wit-response","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":636.5,"y":352,"wires":[]},{"id":"f0b9c456.0f4638","type":"wit-action","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","action":"setLights","x":237.5,"y":429,"wires":[["1b501a10.e4afe6"]]},{"id":"cbc9490c.3436b8","type":"wit-say","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":231.5,"y":248,"wires":[["ceb4d1a6.314b3"]]},{"id":"1c486d28.e3b793","type":"slack-out","z":"a14acd95.5eb53","name":"Slack out","channel":"","controller":"bdde0b8.f4221f8","x":774,"y":215,"wires":[]},{"id":"5cac2acf.a353d4","type":"wit-error","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":793.5,"y":134,"wires":[["76ff9602.890068"]]},{"id":"76ff9602.890068","type":"debug","z":"a14acd95.5eb53","name":"","active":true,"console":"false","complete":"false","x":935.5,"y":134,"wires":[]},{"id":"59324657.a6cdb8","type":"wit-response","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":550.5,"y":424,"wires":[]},{"id":"62b96ee1.9d469","type":"function","z":"a14acd95.5eb53","name":"Save slack in context","func":"return {\n context: {\n source: {\n 'type': 'slack',\n msg: msg\n }\n },\n payload: msg.payload\n};","outputs":1,"noerr":0,"x":413.5,"y":136,"wires":[["4355ed9b.bcaa14"]]},{"id":"edfce749.120318","type":"function","z":"a14acd95.5eb53","name":"Format Slack msg","func":"const slackProp = (msg, prop) => {\n const val = msg && \n msg['context'] && \n msg['context']['source'] && \n msg['context']['source']['msg'] &&\n msg['context']['source']['msg'][prop]\n \n if(!val) {\n return null;\n }\n return val;\n}\n\nvar channel = slackProp(msg, 'channel');\nif(!channel) {\n return;\n}\n\nreturn {\n payload: msg.payload,\n channel: channel\n};","outputs":1,"noerr":0,"x":594.5,"y":215,"wires":[["1c486d28.e3b793"]]},{"id":"546259d5.ab9da8","type":"mqtt out","z":"a14acd95.5eb53","name":"","topic":"","qos":"","retain":"","broker":"b96f8db7.46907","x":550,"y":467,"wires":[]},{"id":"1b501a10.e4afe6","type":"function","z":"a14acd95.5eb53","name":"setLights","func":"var context = msg.context;\n\nvar payload = null;\nif(context['light_description']){\n payload = context['light_description'];\n} else if(context['on_off']) {\n payload = context['on_off'];\n}\n\nif(payload) {\n return [msg, {\n topic: 'nodered-local/ledstrip',\n payload: payload\n }];\n}\n\n// TODO: can we tell Wit that we didnt understand the context?\nreturn [msg, null];\n","outputs":"2","noerr":0,"x":383.5,"y":429,"wires":[["59324657.a6cdb8"],["f6dafb0e.092508","546259d5.ab9da8"]]},{"id":"f6dafb0e.092508","type":"debug","z":"a14acd95.5eb53","name":"setLights Output","active":false,"console":"false","complete":"payload","x":586.5,"y":517,"wires":[]},{"id":"ceb4d1a6.314b3","type":"function","z":"a14acd95.5eb53","name":"Switch source","func":"const sourceType = msg['context'] && msg['context']['source'] && msg['context']['source']['type'];\nif(sourceType === 'slack') {\n return [msg, null];\n}\n\nreturn [null, msg];","outputs":"2","noerr":0,"x":390.5,"y":249,"wires":[["edfce749.120318"],["74017b26.8bfe84"]]},{"id":"74017b26.8bfe84","type":"debug","z":"a14acd95.5eb53","name":"","active":true,"console":"false","complete":"false","x":588.5,"y":282,"wires":[]},{"id":"91829b99.6e7d68","type":"inject","z":"a14acd95.5eb53","name":"","topic":"","payload":"Turn the lights on","payloadType":"str","repeat":"","crontab":"","once":false,"x":302.5,"y":642,"wires":[["437854b3.bc87ac"]]},{"id":"437854b3.bc87ac","type":"wit-converse","z":"a14acd95.5eb53","name":"","app":"33013393.ccfecc","x":516.5,"y":669,"wires":[]},{"id":"400a5b5c.bff5a4","type":"inject","z":"a14acd95.5eb53","name":"","topic":"","payload":"Turn the lights off","payloadType":"str","repeat":"","crontab":"","once":false,"x":297,"y":684,"wires":[["437854b3.bc87ac"]]},{"id":"86bdb34a.79425","type":"comment","z":"a14acd95.5eb53","name":"Testing","info":"","x":242.5,"y":590,"wires":[]}]
