node-red-contrib-wifi370 2.0.2
node-red node to ease the communication with wifi370 led controller
npm install node-red-contrib-wifi370
:bulb: Integrate your WIFI370 LED-Controller with Node-RED
npm version
node-red-contrib-wifi370 provides commands to control your WIFI370 LED-Controller with Node-RED.
Node-RED - is a visual tool for wiring the Internet of Things (IoT) - read more @http://nodered.org
This node outputs a message to msg.payload containing a buffer which can be send to the WIFI370 LED-Controller using the TCP node.
Communication
This node provides bit arrays messages which can be send using the TCP node
How to use this Node?
Talk to WIFI370 with node-red-contrib-wifi370:
Inject node ---- Wifi370 node ---- TCP node
Screenshot
Predefined Commands
  • ON
  • OFF
  • INFO (Current State and Color)
Screenshot
Color
if you pass an rgb Array to this node it will be used instead.
msg.color = [ 255,255,255 ]
Screenshot
Configure TCP node like this
Screenshot
Get current state
Screenshot
Output: data": [ 102, 1, 36, 65, 33, 2, 34, 255, 0, 1, 153 ]
value 3 represents ON/OFF 36/35
values 7,8,9 represents RGB 34,255,0
The Vanilla Way
Talk to WIFI370 only with core nodes
Inject node ---- Function node ---- TCP node
Screenshot
Function node content
var CMD = {
INFO: ["239", "1", "119"],
ON: ["204", "35", "51"],
OFF: ["204", "36", "51"]
const buffer = new Buffer(CMD.OFF);
msg.payload = buffer;
Which hardware is used?
Controller Support
Controller Supported Type
LW12 [x] RGB
LD382 [x] RGB
LD382A [x] RGB
LD686 [x] RGBW
Thanks to Meik Dirkes for reverse engineering the communication for all controller types.
WIFI370-LED Controller
Screenshot
Link to Amazon (Germany): Link
Exported Flow
Find the exported flow example in "test" directory
cd node-red/
npm install node-red-contrib-homematic
Docker Install
On the host machine
docker run \
--name nodered \
--restart=always \
-v /home/docker/node-red:/data \
-p 1880:1880 \
-d nodered/node-red-docker
Also on the host machine
cd /home/docker/node-red
Something missing?
You can easily extend this module to fit your needs by editing the html file. feel free to create a pull request!
Donate
See the LICENSE file for license rights and limitations (MIT).
Version: 2.0.2
Updated 6 years, 11 months ago
2 in the last week
  • wifi370
  • wifi370
  • led
  • led-controller
  • rgb
