node-red-contrib-websocket-gabbo 0.1.1
A web-socket with gabbo support.
npm install node-red-contrib-websocket-gabbo
A web-socket with Auth0 authentication support.
npm version codeship
npm install node-red-contrib-websocket-auth0
Edit the websocket-listener-auth0 node with your Domain value above in the Account setting panel.
  • By default, it checks for the valid auth0's token and pass the request to the downstream node.
  • Request is authorized if the role value is set to the auth0 user's role value. Usually setup by https://manage.auth0.com/#/rules
  • Request is authorized if the group value is set to the auth0 user's group value. Usually setup by installing the Auth0 Authorization 1.4 extension
Try to get your auth0's id_token from your auth0 application and pass it into the Authorization Header
Currently it supports only Bearer token which is taken from id_token parameter.
curl -i http://127.0.0.1:1880/test -H "Authorization: Bearer {{auth0-id-token}}"
Version: 0.1.1
Updated 4 months, 3 weeks ago
3 in the last day
6 in the last week
11 in the last month
  • ws-in-auth0
  • ws-out-auth0
  • ws-listener-auth0
  • ws-client-auth0
  • websocket
  • socket
  • auth0
  • paulredmond79
