node-red-contrib-viseo-socketio 0.3.0
VISEO Bot Maker - SocketIO
Nodes to send/receive data using Socket.io.
These nodes use Socket.io.
This node is part of project node-red-contrib-viseo powered by VISEO Technologies. Please find the node documentation in the Node-RED info tab.
Here is a French Article on Bot Ecosystem and more.
Quick Start
npm install node-red-contrib-viseo-socketio
Client code example
var socket = io('https://myserver.com', { path: '/myPath/socket.io', secure: true });
socket.on('myNamespace', function (data) {
if (data.event) socket.emit('myNamespace', { type: "event", content: 'ok' });
socket.on('disconnect', function () {
console.log('you have been disconnected');
socket.removeAllListeners('myNamespace');
socket.removeAllListeners('disconnect');
socket.removeAllListeners('reconnect');
socket.removeAllListeners('connect');
socket.on('reconnect', function () {
console.log('you have been reconnected');
socket.on('connect', function () {
console.log('you have been connected');
Getting Help
A documentation is available on this Wiki.
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question
tag please specify :
- Your message is a question / discussion
- The module or node name
Contributing
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of VISEO Technology.
- Jean-Philippe Encausse @jpencausse
- Klervi Menoret @klervix
- To-Thi Hoang
- Alice Vasseur @Alice_Vasseur
Copyright and license
Copyright 2016-2019 VISEO under the Apache 2.0 license. Copyright 2012-2019 SARAH under the Apache 2.0 license.
