node-red-contrib-viseo-repeat 0.3.0
VISEO Bot Maker - Iterate on calls between outputs
npm install node-red-contrib-viseo-repeat
Node-RED
Uses different repeat calls according to outputs.
This node is part of project node-red-contrib-viseo powered by VISEO Technologies. Please find the node documentation in the Node-RED info tab.
Here is a French Article on Bot Ecosystem and more.
Quick Start
Build the Node-RED Flow
The repeat node
  • First call: creates a specific counter in a field according to the chosen scope,
  • Sends the message to the first output ;
  • Next calls: retrieves the counter and increment it,
  • Sends the message to the corresponding output ;
When the value is reached, it is possible to select the node behavior:
  • Stopping sending messages ;
  • Reset the counter and continue with the normal node behavior ;
  • Always use the last output ;
The scope can be set to:
  • msg - The current message in the flow ;
  • user - The msg.user field in the flow (can be stored in a database) ;
  • global - The node context (could be not working on multi-server networks) ;
Getting Help
A documentation is available on this Wiki.
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question tag please specify :
  • Your message is a question / discussion
  • The module or node name
Contributing
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of VISEO Technology.
Copyright and license
Copyright 2016-2019 VISEO under the Apache 2.0 license. Copyright 2012-2019 SARAH under the Apache 2.0 license.
Version: 0.3.0
Updated 7 years, 9 months ago
18 in the last week
  • repeat
  • viseo
  • sarah
  • repeat
