node-red-contrib-viseo-random 0.4.0
VISEO Bot Maker - Random call between outputs
Performs random calls according to outputs.
This node is part of project node-red-contrib-viseo powered by VISEO Technologies. Please find the node documentation in the Node-RED info tab.
Here is a French Article on Bot Ecosystem and more.
Quick Start
npm install node-red-contrib-viseo-random
Build the Node-RED Flow
The random
node
- First call: creates an array containing all the possible output values in a field according to the chosen scope.
- Randomly shuffles the array.
- All calls: retrieve the array,
- Gets the value of the last element of the array,
- Deletes this element from the array,
- Sends the message to the output corresponding to the value.
When all the outputs were used, the array is reset and shuffled.
The scope can be set to:
- msg - The current message in the flow ;
- user - The msg.user field in the flow (can be stored in a database) ;
- global - The node context (could be not working on multi-server networks) ;
Getting Help
A documentation is available on this Wiki.
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question
tag please specify :
- Your message is a question / discussion
- The module or node name
Contributing
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of VISEO Technology.
- Jean-Philippe Encausse @jpencausse
- Klervi Menoret @klervix
- To-Thi Hoang
- Alice Vasseur @Alice_Vasseur
Copyright and license
Copyright 2016-2019 VISEO under the Apache 2.0 license. Copyright 2012-2019 SARAH under the Apache 2.0 license.
