node-red-contrib-viseo-ms-graph 0.0.2
Wrapper of Microsoft Graph
npm install node-red-contrib-viseo-ms-graph
A Node-RED node to perform an OAuth2 Authentication with Microsoft Graph.
Quick Start
To use the Microsoft Graph Connect Sample for Node.js, you need either a Microsoft account or a work or school account
Register the Application
  1. Sign into the App Registration Portal using either your personal or work or school account.
  2. Choose Add an app.
  3. Enter a name for the app, and choose Create application. The registration page displays, listing the properties of your app.
  4. Copy the Application Id. This is the unique identifier for your app.
  5. Under Application Secrets, choose Generate New Password. Copy the password from the New password generated dialog. You'll use the application ID and password (secret) to configure the sample app in the next section.
  6. Under Platforms, choose Add Platform.
  7. Choose Web.
  8. Enter https://server.url:1880/callback-auth as the Redirect URI.
  9. Choose Save.
Build the Node-RED Flow
This sample demonstrate an authentication throught a ChatBot.
Flow
Sign-In
The first row build an URL to https://login.microsoftonline.com/common with credentials then send a ChatBot Sign-In Card
Callback URL
The second row
  • handle HTTP GET Request to /callback-auth and answer a "Thank You" message.
  • the callback code is resolved into a refreshToken and accessToken.
  • the callback state is resolved to fetch the ChatBot user, save the credential and send back a message.
API Testing
The third row try to retrieve the microsoft profile with an HTTP request to https://graph.microsoft.com/v1.0/me
Getting Help
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question tag please specify :
  • Your message is a question / discussion
  • The module or node name
Contributing
Before raising a pull-request, please read our contributing guide.
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of Jean-Philippe Encausse for the SARAH home automation project.
Copyright 2012-2017 SARAH under the Apache 2.0 license. Copyright 2016-2017 VISEO under the Apache 2.0 license.
Version: 0.0.2
Updated 3 weeks, 2 days ago
1 in the last day
18 in the last week
122 in the last month
  • ms-graph-oauth
  • sarah
  • jpencausse
