node-red-contrib-viseo-botbuilder 0.5.30
A MS BotBuilder implementation for Node-RED
A Node-RED wrapper on top of Microsoft Bot Builder Framework.
This node is part of project node-red-contrib-viseo powered by VISEO Technologies.
Here is a French Article on Bot Ecosystem and more.
Quick Start
npm install node-red-contrib-viseo-botbuilder
Get Started
Here is a sample configuration to start you server. Switch will route to the convenient SendCard according to business logic.
Requirement
- An access to Microsoft Bot Framework
- An SSL certificate (like Let's Encrypt) declared in node-red-config.js (or a proxy)
- Storage is performed in memory in NeDB or any other third party database.
Multilang
- The profile node handle the default locale
- The user's locale is defined throught MSBotBuilder priorities
- All fields of Card node are translated according to the user's locale
- Locales files are defined in
/data/locales/lang_country.json
The JSON file can be generated from XLSX:
node path/to/xlsx2json.js path/to/input.xlsx path/to/output.json
Getting Help
For further help, or general discussion, please use the github issue tracker and in order to be labeled with question
tag please specify :
- Your message is a question / discussion
- The module or node name
Contributing
Before raising a pull-request, please read our contributing guide.
This project adheres to the Contributor Covenant 1.4. By participating, you are expected to uphold this code. Please report unacceptable behavior to any of the project's core team.
Authors
This project is a creation of VISEO Technology.
- Eric Brulatout @ebrulato
- Jean-Philippe Encausse @jpencausse
- Alice Vasseur @Alice_Vasseur
- Klervi Menoret @klervix
- To-Thi Hoang
Copyright and license
Copyright 2016-2017 VISEO under the Apache 2.0 license.
