node-red-contrib-usbhid 0.0.1
A node-hid (USB HID device access library) wrapper for nodered
Credit goes to node-hid.
You can look up either git to find information on setup, Prerequisites and Platforms to get the node working: https://github.com/node-hid/node-hid
Prerequisites:
- Node.js v0.8 - v4.x+
- Mac OS X 10.8, Linux (kernel 2.6+), and Windows XP+
- libudev-dev, libusb-1.0-0-dev (if Linux, see Compile below)
- git
node-hid uses node-pre-gyp to store pre-built binary bundles, so usually no compiler is needed to install.
Platforms we pre-build binaries for:
- Mac OS X x64: v0.10, v0.12, v4.2.x
- Windows x64 & x86: v0.10, v0.12, v4.2.x
- Linux Debian/Ubuntu x64: v4.2.x
- Raspberry Pi arm: v4.2.x
How to Use
HID ( USB ) read/write access for non root users ( in my case for user pi on an raspberry pi 2 running nodered )
The Pd-extended [hid] object allows you to access Human Interface Devices such as mice, keyboards, and joysticks. However, in most Linux distributions, these devices are setup to where they cannot be read/written directly by Pd unless you run it as root.
Running a non-system process as root is considered a security risk, so an alternative is to change the permissions of the input devices so that pd can read/write them.
sudo mkdir -p /etc/udev/rules.d
sudo nano /etc/udev/rules.d/85-pure-data.rules
Now add the following rules to /etc/udev/rules.d/85-pure-data.rules:
SUBSYSTEM=="usb", GROUP="input", MODE="777"
Then create an "input" group and add yourself to it:
sudo groupadd -f input
sudo gpasswd -a YOURUSERNAME input
Reboot your machine for the rules to take effect. Your nodejs / nodered has now FULL ACCESS !! to you usb devides. Feel free to adjust the permissions to fit your needs.
