node-red-contrib-unsafe-function 0.8.0
The fast and furious version of function nodes
npm install node-red-contrib-unsafe-function
The fast and furious version of function nodes.
Uses require-from-string instead of executing the function inside a vm.
The implementation sticks to the api of the standard function nodes, so if your code worked on a standard function node it should also work on unsafe-function (only faster!). unsafe-function does not run inside a vm and therefore may do unsafe operations (like calling require('fs') and its operations).
Additional Features
nodeRedContribUnsafeFunctionAsyncSend, nodeRedContribUnsafeFunctionAsyncReceive - Set these RED settings variables in order to make the sending\receiving of messages asynchronous. The current behavior of node-red is that sending a message pauses until all the following nodes in the flow finish handling the sent message (unless they specifically do it asynchronously). For more information, see issue 833.
nodeRedContribUnsafeFunctionProfiling: Set this RED settings variable to show for each node a status message with basic profiling information: how many messages were handled and what's the total\max execution time.
Change Log
From 0.3.0 to 0.4.0
  • Using global RED settings nodeRedContribUnsafeFunctionAsyncSend, nodeRedContribUnsafeFunctionAsyncReceive and nodeRedContribUnsafeFunctionProfiling, instead of checking NODE_RED_CONTRIB_UNSAFE_FUNCTION_ASYNC_SEND, NODE_RED_CONTRIB_UNSAFE_FUNCTION_ASYNC_RECEIVE and NODE_RED_CONTRIB_UNSAFE_FUNCTION_PROFILING environment variables.
  • Updating package dependency require-from-string to version 1.2.1.
Version: 0.8.0
Updated 4 years, 9 months ago
278 in the last week
  • unsafe-function
  • function
